View Single Post
Old 10-20-2022, 08:03 PM
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
[QUOTE=comtn4x4;3765914]
Originally Posted by Jetboy View Post
FWIW - It's very likely the result of the bushings. Poly bushings are not an upgrade in many cases and are not appropriate for the rear control arms. The rear control arms require more complex motion than a simple hinge joint like the front suspension. The ends need to both hinge around the center bolt but also twist axially as the link rotates and flex out of alignment as them move through the various suspension motions.
Jetboy, as always thank you for your thorough reply! That makes sense and I'm not arguing at all. But.... if the bushings are the issue and these bushing seem to be a relatively common "upgrade" to the rear suspension. Why is this the only instance I've seen of the upper rear control arms failing?
My bad luck? (That actually makes sense, I am a walking perfect storm) I've run them longer than others? Maybe. (I looked it up I installed them almost exactly 3 years ago, November 2019. about 40,000 miles) It seems really odd to me
I think most people who put them in don't cycle the suspension very far or very often. If you have extended travel rear shocks, that would also add to it. Most of the damage will occur when the suspension is fully articulated. You can probably go lots of highway miles and never have an issue. It just boils down to number of cycles and the amount of deflection. So... take it easy, spend more time on the highways. And you'll be good to go! :P
