Originally Posted by comtn4x4
The new joints are narrower than stock, I assume I'll be needing some washers to take up the gap? I can't imagine not having them in there
You are 100% correct.
The inner shaft of the heim should be torqued solid to the mounts, so use whatever (washers, tubing) to make a snug fit and then torque the thru bolt properly. The inner should not move at all.
