View Single Post
Old 10-21-2022, 01:56 PM
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Originally Posted by psea17 View Post
it is a hi output alternator. but dont really understand the implications of the point youre making.
is there a specific question i should ask the manufacturer or certain features the regulator should have?
appreciate any further info you could share.
I was just wondering if the new alternator had an internal regulator. I'm not up on alternators and thought maybe if the OEM alternator had an external regulator that it might need to be changed as well. I would expect the voltage at the battery to change, particularly right after startup. There would be a heavy drain on starting, high voltage until it reached maintenance level, then remain between 12.7 and 13.1.
While 14 is a little high, it's not bad. As long as you're electrolyte level is okay then you're good to go. If you're constantly adding water then maybe you do have an issue.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
