Originally Posted by phatcheeks
1) Head bolt tool
- I found the CTA tools head bolt tool but I want to be sure that will fit well as I do not want to round out any head bolts. Any reason not to use this one? Anyone use the Toyota tool, 09013-7C310?
I used the snap-on version. Just make sure its a good quality tool because those bolts are on tight. Id use either toyota or snap on. Not sure about CTA quality.
2) Gasket sealer
- Regarding sealing the front timing cover and front part of the oil pan. Is the Toyota FIPG sufficient for both?
I believe its the same. Aisin sells a FIGP which i believe is the same as the toyota one. Its good for timing cover and valve cover.
3) Replacement head gaskets and seals for timing cover and oil pickup
- Are all of these gaskets part of one kit? If so, does anyone have a part number handy?
04112-31720 is what I used.
4) Head studs
- It seems like the consensus is to replace them. I plan to just go with the OEM ones.
I used fel-pro but OEM is always the best.
I agree with phatcheeks on the head bolt tool. I talked to zguy1 in a message, but wanted to add it here. I used the CTA tool when I did it and it was a huge PITA and I ended up stripping a head bolt when I was taking the heads off. It will work, but you really have to wiggle it around to get it fully seated. You'll know it's seated when it makes a "pop" sound, if you don't hear that, don't try to move the bolt. Save yourself the trouble and get the Snap-on or Toyota tool.
