Originally Posted by jazzyfunkykool
... I just looked at the old girl and noticed it's leaning more prominently than I remember. (Edit: it's .5" higher on Drivers side rear, and .25" higher on DF.) I hope the KDSS isn't going out! ...
I have a 2011 Trail, ~125,000 miles, KDSS, Bilstein shocks, Dobinson 1-inch lift front springs and everything else is stock. Checked for lean moments ago with fuel 3/4's full. Rear is equal and right front is +1/8-th inch. Other times, lean is as much as 3/8-ths inch. I stand on the running board, grab the roof rack and begin with a vigorous rocking side to side 6-8 times, then tapering off to a slight rocking while stepping off the running board and that has reduced lean. If the KDSS cylinders and lines are not leaking oil, then your KDSS should be fine.
