Originally Posted by Jivewalker
44psi is because they are an LT tire and not a P tire. The higher inflation acieves the same weight rating as the stock P tire listed on the door jam.
Ive been running the 44 with no issues, just a rougher ride than 32 on the P. If they made a KO2 in P id be all over it for the lower pressure and better ride. Less jarring on the suspension, etc.
And perhaps the most ironic is an E rated BFG KO2 (265/70R17 specifically) ride softest with a 5000 lb vehicle at 45 PSI. Anything less, you lose steering feedback, anything more will firm up the ride significantly.
