Originally Posted by zguy1
So I spent several hours removing the A/C compressor this evening. It was a pain to get to the bolts holding the compressor to the bracket that has the tensioner on it. After much swearing and removing some wire harnesses, I was able to unbolt it and get it out of the way. I was able to remove that bracket as well.
So I am struggling to get the harmonic balancer off. From my understanding it is not pressed on and should come off.
Do I need some sort of a puller still?
I don't want to bend it or break something.
thanks...
their a little tight to pull off, a pulley puller works just fine.
