Originally Posted by mtbtim
I can notice a difference with the lower gears. It feels like it has better acceleration, like a better band of power that it didn't have before. Is it mind blowing? Not really. My rig is just so heavy that nothing is going to change the fact I have an under-powered engine for what I'm carting around, especially when I'm on a trip and loaded down with gear. I don't check MPG anymore so who knows if it affected my fuel economy.
I haven't driven it that far since the re-gear, but the driving I have done tells me the difference isn't remarkable. Would I spend the money on a re-gear again? I probably would, especially since one of the main reasons was to also get an Eaton E-Locker installed in the front diff and I know that locker in the front will be a game changer.
If you had to do it again, would you still go with the 4.88, or do you think the 5.29 would make more sense for higher elevations?
Thanks!
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
