Originally Posted by TRD PANTHER
Which make and model AGM battery did you guys go with?
I ran an Odyssey 34 series for a while and now a Northstar 27F (Northstar no longer exists. They were purchased by Odyssey's parent company Enersys unfortunately) The Odyssey was fine although due to my lack of knowledge I shortened it's life by not maintaining it properly. The 27F size is a great size if you're not going to run dual batteries. Whatever you choose some sort of maintenance will be necessary. Either periodic use of a trickle charger or one of the fuse/diode setups.
