View Single Post
Old 10-27-2022, 05:02 PM
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Originally Posted by shadow247 View Post
I only loosened the motor mounts and jacked it up about a 1/4 inch to get the clearance needed to remove the diff.
In retrospect, I think this was the main issue when I've struggled with front diffs in the past. Sagged motor mounts, the motor sinks down a little, and then you have negative clarance in some critical spots.
It all would have been SO MUCH easier if they used a bolt instead of a nut on that back mount.
JohnMc is offline   Reply With QuoteReply With Quote
