Originally Posted by AuSeeker
When you were removing the manifold nuts, did you use a 6 point socket, or a 12 point socket?
If you used a 12 point socket you still maybe able to remove that last nut with a 6 point socket, make sure it all the way on the nut even if you have to tap it a bit with a hammer, and yes use litte bit of heat on it.
A 6 point socket is always best to avoid rounding off stubborn nuts and bolts, there much more surface contact with the sides of the nut/bolt than when using a 12 point socket, if you don't have a good set of 6 points socket I recommend getting one and using them more often than not.
It was a 6 point impact socket.
