Originally Posted by mtbtim
If it's not totally stripped out and you can still get a decent bight with the allen socket, you should be able to get it off with sufficient heat. Heat up around the plug for around 30 seconds to a minute and give it a shot. If it still won't budge, give it another 30 seconds of heat and keep doing that until the plug gives with moderate force.
If it's stripped out completely, try the chisel method
@ octanejunkie
mentioned.
Or, you can weld a nut on. I bet a muffler shop would do it for you for no more than $20.
This for sure.
You can even try to hammer a torx bit in. Anything that will bite. I have an impact driver set for this sort of thing, and one thing I’ve done the pass is fined a flat head bit that can just barely get wedged in. Then take the impact driver and a hammer. Pop loose every time.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
