Real Name: Ron
Real Name: Ron
Probably limited by one of two things, either gearing or horsepower. If you can't reach "top speed" as calculated, in top gear then you don't have enough horsepower to pull that gear. If you can't reach calculated top speed but are able to reach redline in top gear, then you are gear bound.
MPH= RPM x 60/tire rev per mile x overall gear ratio
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
