Originally Posted by 17Jetta
Let me start by saying, IM SORRY.
I searched high and low and could not find a clear answer to my questions.
Finally made up my mind and put a set of Geolandar G015 275/55r20 on my stock limited wheels.
Load rating on this tire is XL so still a passenger car tire with a higher load capacity, not an LT tire from what I understand. Still slightly confused on this one. To add to my confusion on this. This is a 6 ply tire, with a max 50psi rating. Doesn’t this line up directly with a C rated LT tire?
With the XL rating in mind, what tire pressure should I be running? 32psi like Toyota recommended for the stock 245/60r20 that was on there? Or something a little higher? Max psi stamped on the tire is 50psi.
Appreciate any input.
Because it is still considered a passenger tire, although one that can carry a heavier load, I would assume you would use the TP rating on the door. However, if you want to know for sure I recommend contacting the manufacturer directly. I’m sure they can tell you what it’s the best tire pressure for your vehicle.
