Originally Posted by nissanh
No need to replace the master pump.
I'd recommend try a used booster from a yard as it is way cheaper. Make sure before you pull it check whether it holds vacuum by pulling some vacuum from the tube going into the intake.
I am a little concerned with this option as the part will be as old as the one I'm replacing. I can get a used one for $100 and the Seiken is $630 plus tax right now (partsgeek is the best price I can find) so the used option is tempting.
