View Single Post
Old 11-07-2022, 09:57 AM
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Differential fluid weed sprayer pump
I had one of those Slippery Pete manual pumps that screws to a bottle but I got tired of having to clean and store it.
https://a.co/d/0H2Ct3j
I saw a post on FB and copied it, not my idea, just my execution
I bought a Flo-Master 1-Gallon Lawn and Garden Tank Sprayer, $10 https://a.co/d/gBGULns
Picked up some 3/8" ID Shark bite PEX (1/2" OD) at Lowes, $3
Picked up a 1/2" inline brass ball valve at Lowes, $10
Had some spare 3/8" PVC hose lying around
I drilled out the outlet of the weed sprayer to 1/2" and cut a section of the PEX and shoved it in, it was a tight fit
I used a small section of the 3/8 PVC as a junction between the PEX and the ball valve.
The delivery tube is the end of the Slippery Pete bc it has a nice fitting the stays in the diff, so it was repurposed.
You can pre-charge like a sprayer and open the valve or you can manually pump it like a regular jug-top pump.
I'll be using it this week and will revise my design/execution if necessary.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
