View Single Post
Old 11-10-2022, 05:19 PM
krole krole is offline
krole is on a distinguished road
Originally Posted by Too Stroked View Post
First, you don't want to spray it on the exhaust. It'll burn right off, but it will be one hell of a smoke show. The fact that it burns right off is why you don't want to waste your time there.
As for areas to get, remember, rust generally starts where water and road salt get into a semi-closed area, then sit. So, any closed area such as frame box sections, inside the rockers, down into seams, etc. is very important. Pull the access panels at rear sides of the vehicle and spray down into the seams along the wheel well lip and bottom of the quarter panels.
Yes, you can spray the inner door areas by using the drain holes at the bottom of the door, but make sure you spray both forward and back to make sure the entire bottom of the door is covered. Also make sure you don't spray so much in as to block any drains. Same goes for the hood and hatch. Speaking of the hatch, the latch and striker mechanisms are also important to hit.
One other area many people forget is the spare tire lift mechanism.
Ah, so spray the quarter panel, wheel well area from the inside access panels. Not sure why I didn't think of that.
Mostly just overspray got on the exhaust.
So I think I got
1. pretty much everywhere underneath besides exhaust (including spare tire lift mechanism and inside frame)
2. suspension components and everything around there (not on brakes)
3. rocker panel (removing rocker panel covers and spraying inside and painted metal area
4. inside doors
5. inside hood and hood latch
6. inside rear hatch and latch
7. quarter panel/rear wheel well area from the inside access panels
krole is offline   Reply With QuoteReply With Quote
