Originally Posted by fkheath
I have the RCI skid plates. The install instructions specifically says:
"Many vehicles require spacing the skid plate down to clear the exhaust cross-over. Install the supplied 3/8" thick U-shaped blocks, sandwiched between the skid plate and the frame tubes prior to tightening."
Did you get the 3/8" thick u-shaped blocks? If not, contact RCI for them.
Yeah all is good, the U blocks are installed, its installed at the very bottom of the slot range, still have slight contact. How big a gap did you have between pipe and transfer skid? Also did you have the gap on the two end pieces on underneath wrap around section?
