Originally Posted by fkheath
According to the owners manual, if the tire pressure warning light blinks for one minute, then comes on steady, indicates a malfunction in the TPMS system. The owners manual says to see your dealer then.
Originally Posted by Humble Leader
the most likely cause of this is a faulty, going bad, or dead battery in one of the sensors. if you just installed the tires and they were fine previously, the sensors weren't programmed
the blinking and solid light happens when the TPMS module can't see a sensor or multiple sensors. usually the cause is described above and unless you have the toyota software you can't fix this.
a more unlikely solution is the TPMS module that has gone bad and needs replacing. I don't think I've come across anyone that had to replace their TPMS module (the actual computer component) though
Here's some additional information. Tires were replaced 6 months ago. No issues with the TPMS light until a day ago, so I'm assuming they were programmed correctly at the time of the tire install.
Now here's the strange part. Just came back from running a few errands and no TPMS light. I can't imagine the problem resolved itself. Have to think the battery is on it's way out in one of the sensors..Here's a thought, I think the car battery may need to be replaced, could that possibly cause the issue?
