View Single Post
Old 11-30-2022, 02:55 PM
Humble Leader's Avatar
Originally Posted by JAXJeremy View Post
Here's some additional information. Tires were replaced 6 months ago. No issues with the TPMS light until a day ago, so I'm assuming they were programmed correctly at the time of the tire install.
Now here's the strange part. Just came back from running a few errands and no TPMS light. I can't imagine the problem resolved itself. Have to think the battery is on it's way out in one of the sensors..Here's a thought, I think the car battery may need to be replaced, could that possibly cause the issue?
it would be easy to test the car battery. if your car has been sitting for a while and the last time you drove it was a long enough trip to allow the alternator can charge it fully (probably a few miles), do you get 12.6-ish volts using a multi meter? if you do, battery is fine
likely a sensor issue. it could be one of the sensors was damaged slightly on install and now is breaking down or just needs to be replaced. if you have a limited edition trim with full size spare and it's 2014+ you do have a sensor in the spare - maybe that one is the trouble maker
