Originally Posted by MikeinNH67
#3- Unless I'm mixing the oil seal up with the one I did on a Ford, the crank pulley is what the seal rides on not the crank itself. Easier to do with the cover off in my opinion.
You can see where it rides in the first picture in this thread.
Don't ignore your belt....
I just realized that I missed this post yesterday. I looked at the picture you referenced. I think you are right. This would explain why I was able to pry the timing cover from the top during disassembly. There is no way that the crankshaft seal could be oil tight and also allow a considerable amount play when removing the timing cover.
I’ll know once I get back and take a second look. But again, what you’re saying and with the picture shows seems to make sense. If that’s truly the case, then I will be installing the new seal on the timing cover before I install it.
