Originally Posted by tylertenny
My scanner says that the valve is stuck closed. I bought the filter so I'll put that on when it shows up. I'm hoping that the code doesn't reappear but it sounds like it likely will, based on what others have experienced. I'm just hoping I don't get the additional codes along with it that put it in limp mode. I might have to wait for it to warm up a bit before I disassemble the valve because my garage isn't heated and it's too cold to spend more than 5 minutes working in it.
Shake the valve and listen for any rattle inside. I had the valve plate break in one.
