Real Name: Tim
Real Name: Tim
I think you should check to see if your reservoir screen needs a good cleaning before replacing the pump. A dirty screen prevents optimum flow of fluid from the pump to the steering rack and back. When the fluid is cold, it's thicker, which will restrict fluid flow until it warms up a bit. A clogged screen along with cold fluid is probably why your pump is making noise.
Clean the screen and do a flush of the fluid and see where that gets you.
I have a video for the process.
