I called Fox regarding the issue of corrosion, and they recommended a product called Steel It be sprayed on the springs and bodies. It’s a spray paint with stainless steel particles in it, which is better than regular paint products for corrosion.
I also top coated with CRC corrosion inhibitor, which is a waxy coating.
I disassembled the coil overs when new before install, coated with 3 coats of steel it, and 1 good coat of CRC and reassembled.
Be careful with how much steel it you put on the threaded area, it will be difficult to turn the spring perch if you put more that 2 light coats. I used more CRC in this area as top coat.
Both seem to be working well for me so far.
- Mark
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
