If you truly want a higher performance fog light for your vehicle, the Toyota High Performance LEDs aren't bad, but there are better options out there. (And this is coming from a very big fan of OEM Toyota parts.) There are also far worse options out there, but we won't go there. For the most exhaustive, instrumented, data driven review of most of the available options, I'd recommend this thread:
The LED SAE J583 Fog Pod & Fog Light Review | Tacoma World
One thing I should make clear though is that the above thread addresses "fog" beam / pattern lights, not driving, flood, cornering pattern etc. A true fog beam has a well-defined, flat horizontal beam that fills the area directly in front of the vehicle and well out to the sides. They're designed to allow safe travel in inclement weather by cutting through rain and fog as well as illuminating the sides of the road, so you know where you're going. That said, they don't project very far in front of the vehicle - by design. If by "high performance" you mean something that illuminates significantly further down the road, you may want to consider a different beam pattern.
