Originally Posted by leered
My battery barely turned the engine (2012 T4R LTD) last Monday. Having this battery for over 3 years, I thought it's time for a new one ( bought one but didn't install because I wanted to make sure it is not the alternator causing this).
It turned out battery was only 60% charged . Charged overnight and passed testing the next day ( fully charged). However, I noticed my battery/alternator gauge is a little to the left from the mid line ( 14V) and using a voltmeter confirmed a 13.6-13.8V ( under the expected 14v+). Under load ( AC ON+ FAN @MAX+ HEADLIGHT ON) voltage at battery is 13.58V
Local AutoZone testing of the charging system showed PASS while O'reilly's test returned: REGULATOR FAIL then ALL PASS,.. REGULATOR FAIL.. then ALL PASS...then REGULATOR FAIL.. didn't help at all!
Just replaced the alternator with a Denso Reman and the voltage is 13.6V ( outside temp 99 F)- just like the OLD one!
On Vehicle NEW alternator test @ local O'reilly says REGULATOR FAILED. The old alternator PASSED the bench test ( at O'reilly ! This makes no sense, unless their diagnostic tool is bad .
With the old alternator, I've noticed in the morning ( cooler outside) the voltage is 14V+ while at noon or after driving a while, the voltage goes to 13.6V . Suspected a heat-related issue with alternator/regulator and trying to avoid getting stuck due to a near future alternator-issue, decided to replace it .
During the week I searched but I couldn't find any info on 5th gen T4R charging system. Today, one of the searches returned an article about Alternator Testing and it looks like the alternator output voltage is temperature-dependent. This means that my 13.6V at 99F (14.2V at 68F) is actually OK.
I'm hoping someone can confirm the normal voltage for the charging system . Could not find this or a diagram using Google searches ( at least not for 5th genT4R).
BTW, I've attached pics of the "PITA" rear bracket hoping it will come in handy for the next DIY-er I know I had a hard time just finding the bracket!
Note: I had to remove front/driver side tire to be able to see/access bracket /bolts.
Thanks !
I can't figure out how the harness comes off the alternator. Removed two 10mm bolts on the alternator which loosened the lower portion of the harness, but can't figure how it comes off the plug.
