Originally Posted by drkb63
Thank you for the response also. I called and spoke with someone in customer service. He said the front springs should support the weight of the new bumper and winch. Respectfully, based on the few posts I've read, including yours, I'm thinking there will be a little drop. I'll have to consider a new set of front springs as that will likely be the most affordable option. Thanks again.
You should be running a 650 lb spring rate with that combo. The stage 1 Eibachs are probably 550lbs and will sag about an inch with your bumper/winch combo.
