Originally Posted by inscarguy
The end caps come off. If it did not come with them, you need special bolts from toyota. The regular ones will not work. The ones you need are a flat torx bolt. Also you will need a thread sealer or 3M strip caulk because if these are not used you will leak water into the cabin from unsealed bolts.
Thanks, about to replace mine as well. This was helpful.
