Hmm yea - that is frustrating. Very strange that if it feels like it is binding and had the rack replaced recently that a new rack didnt fix it.
Presumably youre not running huge oversized tires.
Youve replaced the whole steering system and so unless you got another bad part, thats very odd.
Presumably, youre not leaking power steering fluid/ have low pressure.
I believe the 4runner is supposed to use ATF fluid in the power steering set up. I guess if at some point someone was using too high a viscosity fluid in the power steering pump that it would make it more stiff and less responsive.
Have you checked the power steering lines to make sure there is no corrosion?
Otherwise youre left with the tie rods or a bad wheel hub assembly
Good luck
