View Single Post
Old 01-13-2023, 09:51 PM
Gone4Wheeling Gone4Wheeling is offline
Gone4Wheeling is on a distinguished road
Originally Posted by mbm112 View Post
Have you considered the OE size for the 17s? 265/70/R17
Youre also looking at uncommon tire sizes, so consider the availability of replacements should you need one while traveling. Although a matching spare would help, youd still want a replacement sooner rather than later.
They are on my list too. Per specs they would be 11" wide on 8" rim per BFG specs which is wider than the OEM 20" set up.
As I mentioned, I was thinking the narrower 9" would have a couple advantages. I guess the wider 265/70/R17 being an OE size would not cause rubbing issues on a 15mm offset rim, is that correct?
Your point about using a common size if a very valid one to consider.
Gone4Wheeling is offline   Reply With QuoteReply With Quote
