View Single Post
Old 01-17-2023, 08:21 AM
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Originally Posted by drewbux View Post
Thanks for your help, the comment under yours sent a link that is the 5100’s.. What shocks are good for the rear? And your saying with my toytec front springs, I can’t run 5100’s? Thanks in advance
Correct. If you have the TRD Pro bilsteins(which are bilstein 6112) The springs will not fit 5100's as 5100's are smaller diameter(2" vs 2.5"). Easiest way to describe it is this:
-If you go with bilstein 6112's again they only come as a set including springs, but you can swap them out for your toytec lit springs.
-If you go with 5100's you will need to buy new springs.
-5100's would be a downgrade from your current front setup.
For the rear the TRD Pro rears are bilstein 5160's. you could do 5100's in the rear as the main difference is no reservoir; which seems to be more prone to leaking vs 5100's anyway. No diameter difference between 5100 and 5160 so not much of a downgrade if any.
jdm-v35 is offline   Reply With QuoteReply With Quote
