Originally Posted by MikeinNH67
Is it stiff through the whole rotation or more notchy like easier in some spots? How is it with the wheels off the ground? The steering shaft U-joints on these lock up when they get old. It is a replaceable part if that is your issue. Ton's of threads on this and videos on YT.
It’s hard at first like it doesn’t want to go and then it turns easy. But then it’s the opposite turning the other way. Again hard at first and then easy. I should add that I recently had my alignment done when I put on new snow tires. I hope adding the ATF to top up the fluid didn’t mess anything, I have no idea what was in it previously. The cap says to put in dexron fluid. I picked up the ATF fluid from the Toyota dealership.
