Real Name: Jeff
Real Name: Jeff
i try to do all my own wrenching when i can with the help of tims vids ..
not much time lately & havent gotten to front yet ..
did rear with new oem bushings "rear lwr control arms/trailing arms" + springs & shocks ..
currently im undecided exactly what im doing in regards to "pck" .. so havent gotten there yet..
there was a forum memeber here not long ago selling Dobinsons front springs practically new ..
have a pair of used billy 5100s i purchased locally cheap so i have dobbi spring billys and new dobbi top hats ready for install but when budget allows id almost guarantee ill be swapping out the billys unless im somehow floored with the ride. (currently running original coilovers
Diff drop, i ordered one from Sonoran Steel, then watched "tinkerers adventures" vid on u tube regarding diff drops so currently undecided if ill even install it. im currently running 265/70/16s & undecided if ill chg tires size to 17s, its a possibility, if i do then i might install diff drop which will still lv me with a net gain in clearance with the 17s. also the dobinsons i have are the 276s which with my current 99talls wil only negate me about a1inch lift from current setup so i dont think i need any extended cvs.
if id had my choice of dobbinsons fronts i wouldve prolly gone with the 134s vs the 276s
