View Single Post
Old 01-23-2023, 06:53 PM
spartacus's Avatar
spartacus's Avatar
Originally Posted by MikeC82 View Post
Did you ever find a solution to this problem? I have a similar issue. 2019 SrR5. I shipped my vehicle from the US to Africa, and when it showed up five months later, someone had removed the driver master switch. I ordered a new switch from Toyota, and it will not roll down the passenger side window. The passenger side switch will roll down the window; however, the auto-down feature does not work. In addition, when the child lock button is engaged, the driver master switch will only roll down the driver window and nothing else.
May or may not work. Wouldn't hurt to give it a shot.
Disconnect the battery for 5 to 10 minutes.Reconnect.
Now turn on the ignition, but do not start the engine.
Push down on the passenger window MAIN SWITCH only for 5 seconds.
Pull up on the Passenger window Main Switch only for 5 seconds.
This should reset the switch module. I had to do it on mine after I left the dome light on for a few weeks and drained the battery.
