Originally Posted by 4runherpow
Thanks
@ aemravan
Really good info. Interesting on the “dial in” part.
So I did the spark plug Fowler fix today. Had to pay a machine shop $20x2 holes so I could get the o2 sensor to fit and open up the bottom hole for a little more flow. $40 bucks took him 5 mins lol. Oh well. All good.
So the light stayed off all day. Good sign but not out of the woods - as you mentioned.
Interesting observation though:
So the truck seems like there is ever so slightly less torque at the bottom range, but the power band feels a little smoother. I definitely have to press on the accelerator a bit more to get the torque.
At first I thought it was the computer resetting since I disconnected the battery, but it’s stayed that way all day. It’s slight but definitely quieter and little less low end torque, maybe like 5-10 ft lbs. total guess.
Any comments on why this would be. Also, is it bad to have one bank with this workaround and not the other bank of cylinders? This may seem dumb, but is there a downside to this fix like I could run too lean or rich and damage the engine?
I need this girl to last!! I do plan on doing the manifolds this summer just need to find someone that won’t crush me $$$
Do you have a obdii scanner? That would be a really easy, guess-free way to figure out if your light is going to stay off or not. Like I mentioned, the O2 sensor and Catalytic converter system initializations tend to take quite a bit of driving to get situated. With the scanner in you'd see right away if all systems are a GO or still initializing.
Depending on how long you drove for, and under which conditions, it may be leaning towards the positive side with the light not on.. if the sensor was really far out it tends to throw a code pretty quick.
