View Single Post
Old 02-01-2023, 08:00 AM
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Originally Posted by Alex Zandonella View Post
Hello! I've got a similar problem, as I couldn't start my own thread I thought posting below this one as the problem is pretty similar. I've got a 2nd generation 2,7l Toyota of 1995. Until a month ago, everything was working fine then out of the sudden on sudden days the motor didn't start, and on other days without problems. This worsened and now most of the times it doesn't start but still sometimes it starts. So my first thought was the starter motor. After buying a new one and replacing it, it worked again for a day and then had the same problem. I just keep hearing the click of the starter relay but nothing happening. The cables should be fine as I measured the 12V on the main cable of the starter. I thought about the relay between the key and the starter, but couldn't really find it. A few relays at the drivers site were my guess, so I tapped them when the car wasn't starting, still nothing. Does anyone have an Idea what might be the problem? It has to be something electrical otherwise it would work sometimes and sometimes not.
Greetings from Italy!
Alex
See here:
Starter Relay Re-Wire or Retrofit for 95 and earlier Trucks / 4Runner - YotaTech Forums
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
