Ignition Switch - No spring tension, ETC. !!!SOLVED!!!
All, thank you for your assistance.
2006 T4R sr5 2wd v6
This began with the 4R not turning off when the ignition switch was turned to the OFF position and the key could be removed and the engine would continue to run. It could also manifest as a failure to crank - turn key - nothing happens.
The ignition switch has no spring tension. The key does not return to any position under spring tension.
At times it will spin 360 degrees with no resistance and at other times, it is normal but with no spring tension.
Purchased new ignition cylinder. It has no spring tension either.
4R will not start with the new ignition cylinder. The battery is new. It is not the relays. It is not the starter. It is not the fuses.
What provides spring tension to the ignition switch?
Any ideas?
