I just put on a complete 99' Fed emissions OEM exhaust from downpipe to tail pipe with no regrets, its available still and expensive but its good for the next decade or so, and came with the rubber anti-vibe insulator infront of the muffler that Ive never seen, I also added all new O2 sensors & hardware, and the O2 sensor SS covers from the Sequoia, tapped all the crimped OE nuts for easy maintenance in the future, no emissions here but any other options will last half as long and cause more downtime and frustration if you can't weld exhaust(especially in the rust belt), unless it's very high end aftermarket.
