[QUOTE=Bad Luck;3785381
EDIT and slight rant: Why are people assuming it’s the head gasket? Isn’t it much more likely that there’s air pockets in the cooling system from having to drain the system to replace the radiator?
Where has diagnostic reasoning gone? Ever since I did “X” then “Y” has happened. THAT’S BECAUSE “X” CAUSED “Y”!!! “Ever since I pulled this fuse my radio stopped working, could it be the battery?” NO!!! IT’S THE MISSING FUSE!!! “Ever since I replaced my valve cover gaskets I got a P0171 lean code, could it be my injectors or my air/fuel sensor?” NO, AGAIN! IT’S THE VACUUM LEAK YOU CAUSED BECAUSE YOU DIDN’T PUT THAT VACUUM HOSE ON OR DIDN’T PUT THAT INTAKE GASKET BACK! See where I’m going with this?…[/QUOTE]
That's not a rant that is in fact trouble shooting 101.
