Originally Posted by Jubsz
Red(power) - Planning to use an add-a-fuse to the box to power on with ign
Black (ground) - This is the one that needs to be spliced to the white w/ green stripe wire on the DAC plug - This should allow the switch to dim?
Yellow (dash light circuit) - Spliced to green wire from DAC plug - is this switched 12v when the interior lighting is on?
Problem solved. I connected the wires as noted above (to DAC plug) and things are working perfectly. Switch is matched to interior lights, including dimming.
