Originally Posted by revans611
I think you are probably right about OEM vs auto store parts. I once had a horrible experience with a non-OEM clutch pressure plate. It "shuddered" when starting off in 1st gear. Took it back to the mechanic who installed another non-OEM part with the same result.
Then I phoned in to a local radio station car repair show. The very experienced host suggested that I go OEM. I did, and the problem was solved.
There's a few things that I'm okay with not using OEM parts for, but for the most part I try to stick with Toyota stuff. It just all depends.
