Originally Posted by poisedforflight
From the article it does not sound like they'd work on my '98.
“BLACK” – Toyota 90119-10933; Bolt with Washer. This bolt is specified for the 2001-2002 4Runner, at locations with the protector boot. It is longer than the other bolts, to accommodate the extra thickness of the protector boot. The “11” head markings also classify it as a Class 11T bolt. The captive washer makes this bolt quite different from the flanged heads of all the other bolts.
Everything You Always Wanted to Know About Lower Ball Joint (LBJ) Bolts - and More!
They'll work great! The only thing to watch for when using the longer bolt with washer without the boot protector is that the protruding threads will come very close to the CV boot clamp. Depending on how tightly the clamp was pinched, you may need to mash down a bit on the clamp's pinch (see below).
