Originally Posted by 3bears
I want it to switch off when ignition is off.
Wire the 'power' side of the relay directly to the battery. Wire the coil side of the relay (power to the switch -> relay) to any ignition power source inside the truck. You CAN but don't NEED to put a fuse on that, since it will already be fused by the truck wiring.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
