Originally Posted by Spiker Engineering
Interesting find! I'm probably going to go with their standard engine enamel paint, with some etching primer first.
Paint needs scratches or a rough surface to stick too. I used etching primer before seems to work. You can always hand sand with wet sand 180 then primer wed sand 300 then primer again. After that's cured go for the enamel top coat. Depends on how smooth a surface you want it to be when completed.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
