Originally Posted by Pyral
So if you want something as robust as the original part, your only option is to go with hydraulic hoses.
In a nut shell. Doesn't have to be hydraulic hose just the appropriately constructed higher end rubber hose correct dimensions.
Better grade of hose than I've found in chain parts houses.
Find a one stop shop for an ace up your sleave if/when you need a HP hose.
