Youre able to see and move the latch back and fourth easily? Its not just the motor you hear? IE no sand/ debris getting in the way
It sounds worse than it is to take it apart. Unscrew the rope handle, unsnap the inner panel. Remove the weather strip liner. The actuator has a plastic cover - take it off. Make sure the levers move freely. Try to clean out best you can. Check all the connections
