Originally Posted by Bundutrailer
Th ask for the feedback thought it was extreme. Anybody replaced these here? Experiences?
Are you still wanting to replace them, even after being told you most likely don't need to? Post some pics of some of the body mounts. Like I said, they probably don't need replacing.
They aren't super difficult to do. There is a through bolt with nut, a top bushing and bottom bushing with a large washer at each end. If you do one at a time, you can replace them without having to worry too much with supporting the body. You might need to jack the body up slightly to make room for the new mount. This can be done with a floor jack and a couple pieces of 2x4.
The biggest headache is removing front and rear bumpers to get to the body mounts on those corners and interior trim to pull back the carpet where the body mounts are directly under the cab.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
