Originally Posted by Outsider1
Hello, I just finished replacing the lower intake gasket with Oem ones and I changed the bypass pipe gasket as well but I noticed, after filling the reservoir that after I drive that it still goes down. For the gasket I used the Toyota gasket maker that’s for the transmission pan an let I cure for 24hrs before starting the car
If you do not have any leaks and do not smell antifreeze just keep topping off the tank as trapped air gets purged from the system. It takes Around three heat cycles with a properly operating Rad cap…..
