Lift Lean
Most people here I'm sure have moved on, but for posterity: Yes. Toyota actually uses side-specific springs. The Driverside springs might be a hair stiffer or a hair longer or have an extra coil wrap, but Toyota compensates from the factory in some way. Aftermarket springs installed for a lift usually are L/R interchangeable and don't differentiate, causing the vehicle to lean to one side. From what I've read, typical leans range from 1/2" to 1" with most being in the 1/2" to 3/4" range after lifting.
