so is this problem solved? no update?
air, fuel, spark.
make certain your fuel system is venting, pull gas cap. Check all your fuel lines, see you have pressure. coil wire, distributor. got spark?
id be looking at fuel filter first, cuz its cheapest. clogged fuel line or jett will do it. then fuel pump/reg. Is it pumping, can you hear it?
Couple Yotas
Iluv4xToys!
